Restoration & Repair Tips Board
TRIALER LIGHTS
Dan
02-12-2004 07:21:01
The directional lights on a trailer hooked to my truck flash the opposit direction of the truck. They worked OK until I had a repair shop try to install an electric brake controller. I don't think the brake controller ever worked. When I returned to the shop, they said it had just blown a fuse and they fixed that. I have a 97 F150 with a trailer tow package, this should be a simple hook-up, I thought. What is wrong?
Van in AR
02-12-2004 08:56:19
 Re: TRIALER LIGHTS in reply to Dan, 02-12-2004 07:21:01
Sounds like your left/right turn signal wires are backwards. They maybe backwards on the truck but if it has the trailer towing package I doubt it. You trailer is probably wired backwards. Look at this link below and It will help you fix this problem.
Van
Van in AR
02-12-2004 08:57:14
 Re: Re: TRIALER LIGHTS in reply to Van in AR, 02-12-2004 08:56:19
Heres the link
http://www.mcshc.org/Wiring/plugs.htm
