Restoration & Repair Tips Board
David Brown 880a farm tractor need help with hydra
ginny
02-15-2004 13:39:44
selectomatic live drive lift will not work with a load need help pump is new. making a slight screming noise in the left are facing the rear wear the pull to engage lever is .the filter is clean help get ajustments right and figure it out we are stumped.
CRUSADER
02-16-2004 09:02:46
 Re: David Brown 880a farm tractor need help with h in reply to ginny, 02-15-2004 13:39:44
Check your supply lines to the pump. One of them may be clogged or have come loose and not be supplying the proper amount of fluid to the pump. It's been a while since I have seen much less worked on a David Brown tractor. But if memory serves me right there is a valve/lever under the right side of the seat on the lift housing that limits the amount of pressure going to the lift. Hope this is of some use for you.
later days mate,
Jim
ginny
02-16-2004 11:31:44
 Re: Re: David Brown 880a farm tractor need help wi in reply to CRUSADER, 02-16-2004 09:02:46
sorry but the lines are clear also it only has interal lines none outside now what do i do
