Restoration & Repair Tips Board
Hints to Increase Engine Performance???
Scott
02-21-2004 09:04:13
Hi, Does anyone have some hints for increasing engine performance for a 9N. I will be rebuilding mine soon, and want to squeeze more HP out. Was thinking of a Funk v8 conversion, but decided I wanted to keep the old girl stock looking. Any help would be great....
Scott.
Alvin n Ms.
02-22-2004 08:44:27
 Re: Hints to Increase Engine Performance??? in reply to Scott, 02-21-2004 09:04:13
Scott, those little tractors had more power than they needed, when they were new, and thru the 1950s. I wish someone could explain how all the power just vanished into thin air. The jobs I see them doing now, that takes 1st gear, we used to do in 3rd, with power to spare. Those tractors have modified model A Ford engines, with cylinder sleeves to reduce the piston size, to prevent the engine from being overpowered. alvinnms
TO35
02-21-2004 14:26:46
Compression,Carberation and Flow for starters...
More compression equals more HP...More fuel also needed....and getting it there and out(flow) makes it more efficent...thats where I'd start,
If you want to get serious,ramp speed and durations(cam) also help alot. Also ingition voltages need to be up( I like to convert to electronic) I have re-ground several cams for contiental engines and dyno'ed the engines and the gains are significant.
There are alot of ways to gain hp...so far I've found these to be cheapest and most reliable...and stay stock apearing...
hope this helps..
best wishes
TO
