Restoration & Repair Tips Board
Zama carb problem for Stihl FS85T
Barry Lindler
02-24-2004 16:18:46
I have a used stihl fs85t with a zama carb. I have rebuilt the carb and got it running, but it will only run if the choke is full on. with the choke on, I can adjust it, and accelerate, but when I start to take the choke off, the engine speeds up a bit then shuts off. I have cleaned the carb many times, and rebuilt it. I have tried it with new fuel lines as well, but I have the same problem. I've checked the fuel filter in the tank, changed the air filter, and cleaned the muffler. I'm very frustrated. Does anyone have any ideas? Is it okay to run it on choke? Any help would be appreciated!
Thanks!
Van in AR
02-25-2004 07:32:59
 Re: Zama carb problem for Stihl FS85T in reply to Barry Lindler, 02-24-2004 16:18:46
If the carb is good and sealed to the head good and all of the fuel lines are good the next thing I would check is the crankcase seals on the end of the crank and between the jug and crankcase. A air leak here will make it run way lean and the choke richens it back up.
van
Barry Lindler
02-25-2004 08:51:08
 Re: Re: Zama carb problem for Stihl FS85T in reply to Van in AR, 02-25-2004 07:32:59
I'm hoping that is a pretty straight forward thing to check, as I have never done that- but if I can tear down and rebuild a carb, I should be able to check what you recommend- any tips before I start tearing the engine apart?
thanks,
barry
Van in AR
02-26-2004 18:21:57
 Re: Re: Re: Zama carb problem for Stihl FS85T in reply to Barry Lindler, 02-25-2004 08:51:08
If you have a air hold fitting tool you can take the carb off and bolt up a dummy plate with a gasket and put about 5 PSI on the spark plug hole. Move piston up to cover exhuast port, then listen for the leakage or spray soapy water around crank seals etc. Other than that I would say just change them out, as you already have some money invested in the saw.
Van
