Restoration & Repair Tips Board
Ford 2N Hydraulic woes
Pete Blanck
03-02-2004 11:47:32
My 1942 2N hydraulics do not seem to respond to the position of the quadrant lever. Starting at the bottom of the quadrant, the lift arms will rise to the highest position if the quadrant control is moved to any upward position. Intermediate steps between highest and lowest points make no difference. The same happens on desent of the lift arms. Is this the way it was designed or do I have a problem (and if so, whats the cure)? Many thanks, Pete in Mass.
Bob
03-03-2004 10:31:27
 Re: Ford 2N Hydraulic woes in reply to Pete Blanck, 03-02-2004 11:47:32
Your 2N was not designed with "position control".
It only has draft control, a feature that raises and lowers a plow, or other drawn implement in response to the load on the implement, so the load on the tractor remains constant.
Go to: >Link
And>Link enter "position control" in the search box. I just did and got 2258 "hits". There are various explanations of the 2N system, and descriptions of an option or two to add position control to your tractor.
