Restoration & Repair Tips Board
Z134 Block with bolts
Chad Delaune
03-06-2004 20:21:10
I have a Continental Z134 and It has bolts run inside the block like it is holding it together. Someone told me that it was used to repair a cracked block? Between two sleeve there is a crack, but as far as I know before I tore it down there was no oil in the radiator nor was there radiator fluid in the oil. Will it be good for a rebuild?
george md
03-09-2004 21:02:16
 Re: Z134 Block with bolts in reply to Chad Delaune, 03-06-2004 20:21:10
Chad, Many of the Z series and the J series cont'l
blocks are bolted as a repair for cracks in the deck. Usually when a fellow goes to the trouble
to bolt them he grinds out the crack or cracks ,
welds , planes the deck ,and recuts the counter
bores . Look for a crack down thru the center webbing and all the way thru the center main . Z series are noted for that , especially the Z 120 .
Chances are the block will serve you well .
george
