Restoration & Repair Tips Board
Clutch not working
Ed
03-10-2004 16:44:44
I have a 1959 fordson power major. The clutch will not disengage at all. It was working fine and then suddenly wouldn't disengage.
The external linkage is okay. What might be wrong?
Ed
old
03-10-2004 17:34:12
 Re: Clutch not working in reply to Ed, 03-10-2004 16:44:44
Some of them old fords like to have stuck clutchs its probably just needs to be worked out, my 8N does that unless I keep a cement block on the clutch when its parked. You can try to unstick it by starting it in gear and holding the clutch down and hit the bracks hard and letting up on the brakes.
