Restoration & Repair Tips Board
Conversion 6 to 12 volt wiring kits
velvet ride
03-24-2004 17:30:36
Currently have the rebuilt 12V Gen, VR, need a decent wiring 'harness' package, to replace the
ratty 6V clutter. The tractor is a M.Harris 44G.
Helped someone do a similar task, a few years back, was more of a roll of wire, some clamps,
one kit converts all, royal headache. Not looking to gold plate the fifty year old 44,
but what has some directions, better wire, cables, for a row crop 50HP tractor? Faded farm
country around me, so the green dealer 30 miles
away, is not an old red admirer. Thank you.
Jerry B
03-26-2004 06:16:55
 Re: Conversion 6 to 12 volt wiring kits in reply to velvet ride, 03-24-2004 17:30:36
HUH????? ?
I think you are asking is: "Is there a replacment wiring harness for a Massey Harris 44?"
You can check with Value Built. They might have one. It won't be cheap.
The cheapest and simplest way is to rewire it yourself using a few rolls of different gauge wire, some solderless connectors and a good set of crimpers. Use wire ties to hold everything in place until you are certain all is correct and works perfectly. Then wrap in a good quality tape or use split plastic wire looms.
Thorough knowledge of the way the electrical system should be wired is mandatory.
