Restoration & Repair Tips Board
2400A or 454 IH power steering.
David
03-24-2004 20:08:42
I have an IH 2400A that the power steering operates as if the engine was not running. It is very hard to turn. Fluid level is ok, new fluid & filter. Lift works, but some times comes all the way up un-stopable on its own. Brakes work ok. No noise (as with air in system), PTO operater ok.
Where is the flow divider and does it have a MCV as 454. Haven't found any dealers around to check with. Thanks
