Restoration & Repair Tips Board
Ford 601 workmaster
Mike
03-26-2004 17:51:53
tractor will start run approximately 30 seconds then shuts off like turning off the key. replaced coil, points, and condensor. will not start back up, wait an hour then will start and die. has been converted to 12v negative ground system. Anyone know what the problem is?
redrider1127
05-02-2005 18:58:06
 Re: Ford 601 workmaster in reply to Mike, 03-26-2004 17:51:53
have the same problem. 2 suggestions.
First the key switch is bad and had to jiggle with it, back it off from full on a little until the voltmeter shows a discharge.
Second, may be the float in the carb is sticking. I bang on the carb bowl and the problem resolves itself.
Randy
03-29-2004 01:47:28
It might be the fuel line/filter/sediment bowl is clogged not letting enough fuel thru
old
03-26-2004 18:22:53
Sounds like it could be the key switch try hot wireing it I bet it will run if you do
