Restoration & Repair Tips Board
Clutch replacement?? on Fordson 9N
Mike
03-30-2004 11:18:56
A friend of mine has a Fordson 9N that is acting up on him. When he puts the clutch pedal down, it makes a considerable amount of steel hamburger (Grinding) before he can get it into gear. Then has had problems geting it out of gear. He has taken it (supposedly) out of gear and it keeps on going. This does not sound like a a worn clutch so much as linkage not engaging/disengaging as required.
Any thoughts/experiences? If there is some internal adjustment, what and where? Or can it be that the clutch plate is shot?
Mike
JMS/MN
04-01-2004 11:32:56
 Re: Clutch replacement?? on Fordson 9N in reply to Mike, 03-30-2004 11:18:56
Could be a bad throwout bearing.
Bob
03-30-2004 15:15:52
While it is certainly possible that the clutch has failed, the most likely scenario is that the lined clutch plate is stuck to the flywheel and/or the pressure plate by rust or corrosion from the tractor sitting unused.
Ford 'N oldtimers have been known to block the clutch peddle down with a block of wood to prevent this from happening during periods of non-use.
Once it has happened, try blocking the clutch peddle down for several days, and being SURE the ignition is off, have a helper help you to roll backwards and forwards on the rear wheels as severely as you can, with the transmission in the highest gear.
If this doesn't work, and he is driving it around, try to coast it downhill, and slip it into one of the highest gears, in an open area, for safety. Keep foot on clutch, and jerk tractor with brakes while working the tractor by driving back uphill. Sooner or later, the clutch plate should break free.
old
03-30-2004 11:40:02
It could be that it needs to be adjusted or he parks it with out blocking the clutch pedel down, those old tractors like to have the clutches rust up and then they can be hard to get the clutch to release as they should.
