Restoration & Repair Tips Board
H worm gear bearing
bigdan
04-02-2004 21:14:41
Looking for the bearing size on the end of the worm gear on a 49 H tricycle steering. Also the nut thread size and cut. If you have a bearing number/type it sure would be helpful. Thanks
Dick in Fallon
04-03-2004 13:08:00
 Re: H worm gear bearing in reply to bigdan, 04-02-2004 21:14:41
Hi Dan, Here are the IH parts catalog numbers for the steering worm shaft bearing assembly.
Bearing ST 225 BT
Bearing retainer 6660 DA
Steering worm nut(slotted hex jam nut3/4SAE)
All of the above are available at Bates Corporation (8oo)248-2955.
I just ordered the same less than2 wks. ago, hope this helps, Dick
CNKS
04-03-2004 12:36:20
THe IH number for the bearing is ST 225 BT, IH should have it or a good bearing shop can cross it cheaper. The slotted nut is 3/4 inch fine thread, IH# 69442 D.
