Restoration & Repair Tips Board
John Deere Model 330 Transmision Noise
Alan
04-04-2004 16:48:25
I have an old two cylinder JD 330, and I have replaced every cup and cone bearing in the transmission. I have also had a machine shop re-work the input shaft and first gear cluster and replaced the roller bearing there too. The only bearings that I have not replaced is the roller bearings on the power shaft, but tyeh looked pretty good. The transmission is still noisy. It sounds like metal slapping together. Am I trying to get this thing too quiet, or is there a certain amount of noise that should be expected? Any help would be appreciated. Thanks, Alan
Gene Davis (Ga.)
04-04-2004 20:46:12
 Re: John Deere Model 330 Transmision Noise in reply to Alan, 04-04-2004 16:48:25
Are you using the right oil in it. Worked for JD when these tractors came out and they reccomended a type scl 85-140 oil. Of course they took the scl oil (sulpher chlorinated lead) oil off the market years ago,. Be sure you are using a EP(extreme pressure) type oil in it. Also if the ring gear/differential carrier bearings get rough they will sound like a transmission noise since they are in the same housing .
