Restoration & Repair Tips Board
followup for cnks
clean John
04-07-2004 12:21:54
Finally got back to receieving my emails.
On the gookumpucky post___I had no problem with the pan gasket and I've had the pan off three times with the same gasketThe first 2 times I used copper spray but after the trouble with the vertical gastet leaks I used the Napa Ultra black
on all the joints and no leaks. Sorry abt being so late on this and there may be more that I haven't read!!!! John
CNKS
04-07-2004 13:41:27
 Re: followup for cnks in reply to clean John, 04-07-2004 12:21:54
Thanks -- Currently the oil pan has no gasket -- I used a Permatex product sold by NAPA called "The Right Stuff" -- still has a couple of small leaks. If I do it again it will be with the same product and a gasket. $15 a tube!! I didn't use a gasket with it because it sets up fast and says to install within 5 minutes. I didn't think I could get both sides coated and get it together that fast, but later found I could probably take 15 min or so. I appears to be good stuff and I will use it on the other parts I can quickly assemble. It is not for head gaskets, though.
