Restoration & Repair Tips Board
1206 IHC Farmall Hydraulics
kansas country
04-09-2004 18:43:04
I have replaced the pump and the relief valve on my 1206 IHC but still don't have any hydraulic pressure. Any thing else I could check?? The 3pt arms come up but can's lift much. I have put a loader on the tractor but can barely lift the empty bucket??/
Joe Evans
04-13-2004 19:15:51
 Re: 1206 IHC Farmall Hydraulics in reply to kansas country, 04-09-2004 18:43:04
Consult your manual if you have one. I hardly know a thing about -06 hydraulics, but if your manual mentions an item called a regulator/unloading valve, I would speculate the piston of this valve is stuck open. This could be from a galled piston bore or jammed O-ring seal. This condition will allow oil pressure to dump and not allow the system to develop pressure.
