Restoration & Repair Tips Board
8N Steering problem
JIM G
04-16-2004 11:11:33
My 1948 8n was bought with both wheels turned to the middle. Could it be the steering gears just jumped or is it the whole cluster. Jim
jake
04-17-2004 07:56:40
 Re: 8N Steering problem in reply to JIM G, 04-16-2004 11:11:33
The gears can not jump out of position, the side plates were probably taken out and replaced without knowing how to time the gears. Remove both both side plates, turn the steering wheel both directions, determine the center then take the double sided gear on the forward side plate, mesh the center tooth with the center of the toothed block. And finally the rear side plate centered slide in and all gears are properly aligned. Sometimes there will be an arrow on the rear gear indicating mesh alignment point. If the steering column has excessive play the bearings in the gear box could be damaged but this is an easy fix also. Once taken apart you'll see how simple it is.
