Restoration & Repair Tips Board
Rust Prevention Inside Carburator Bowls?
AWB
04-18-2004 07:56:32
I have a cast iron carburator bowl which always rusts a lot on the inside and contributes to fuel contamination. Is there anything that can be used to cure this problem? Thanks.
George
04-18-2004 15:23:00
 Re: Rust Prevention Inside Carburator Bowls? in reply to AWB, 04-18-2004 07:56:32
Never had that problem. Do your engines sit up for a long period of time?
To reduce rusting, I think if you cleaned the surface real well and painted on a couple coats of gas tank sealer (available at most motorcycle shops) would work.
Rusty Jones
05-09-2004 16:34:00
 Re: Re: Rust Prevention Inside Carburator Bowls? in reply to George, 04-18-2004 15:23:00
Keep the water out of yer gas can and fuel tank! Use some dry gas, or laquer thinner, and Sta-bil for winter storage, or even where it doesn't get winter cold! RJ
