Restoration & Repair Tips Board
Drain plug shot
Brad
04-20-2004 19:20:38
The plug hole on the side of the block is rusted out. The threads are for the most part gone. I think its a 3/8" pipe plug or drain fitting. How should I proceed to fix this problem. The tractor is a 1943 Farmall M ..... thanks
Bob
04-21-2004 11:22:31
 Re: Drain plug shot in reply to Brad, 04-20-2004 19:20:38
Clean and dry the hole. Using epoxy (JB Weld, for example), install a brass reducer bushing in the hole and snug it up the best you can, and allow the epoxy to thoroughly harden.
Then, install a smaller plug in the reducer bushing.
Road Warrior
04-20-2004 20:58:50
If you have room, you could drill it out and tap for 1/2" pipe. Or maybe find a rubber plug like a boat uses that has a bolt in it that expands the plug inside the hole.
