Restoration & Repair Tips Board
axle rebuild or replace ??
chopper
04-21-2004 05:58:06
The key way on my case vac tractor axle is no good, I can fill with weld then grind in new key way but not sure if this would make axle brittle or should I replace axle. can I weld on it????
steve
04-26-2004 20:10:27
 Re: axle rebuild or replace ?? in reply to chopper, 04-21-2004 05:58:06
i would go ahead and weld on it. one trick we do a work with big pump shafts is to rotate the shaft 90 degrees or 1/2 revolution, and cut another keyway with the mill. works every time, never broke a shaft yet. for home use, might be easier to fill in the bad spots and regrind.
