Restoration & Repair Tips Board
glow plug question...help
Dustin
04-21-2004 19:47:25
i have a 70's? hinimoto e15...from tokyo japan. When trying to start the negative battery cable bolt at the chasis glows. The only thing i can find is when the ignition is on i get continuity from positive wires at starter to ground. At the ignition switch i only get continuity from glow plug wire/prong to starter wire/prong when ignition is on. normally when starting you hold ignition back to power the glow plugs...then you turn it clockwise to start. I dont know if this is normal or not and but its the only thing I can find. When problem first started the hood pushed the positive wire to starter from batterry against the engine. I really need to mow!! anything is appreciated..thank you
txblu
04-22-2004 18:14:55
 Re: glow plug question...help in reply to Dustin, 04-21-2004 19:47:25
Dustin is on it.
What you didn't tell us was that your battery was discharged as a result of the accident.
Probably, a recharge of the battery, after what Justin said will probably fix your problem.
If not what do you have to loose; get back in here and we will go from there.
txblu
txblu
04-22-2004 18:17:25
 Re: Re: glow plug question...help in reply to txblu, 04-22-2004 18:14:55
Geez. ERROR. What Bob said..... ..
But B4 you crank up again obviously, get the hood off the battery term. (You didn't have to say that) Ok I'm being fecious.
Best,
txblu
Bob
04-21-2004 20:47:22
You have a crudded up connection, where the bolt is getting hot on the chassis. Clean it up down to shiney metal, and replace the negative cable and the bolt, if necessary.
Dustin
04-22-2004 11:00:56
 Re: Re: glow plug question...help in reply to Bob, 04-21-2004 20:47:22
alright, will do. Appreciate it. Would that keep it from starting?
Dustin
04-22-2004 19:48:49
 Re: Re: Re: glow plug question...help in reply to Dustin, 04-22-2004 11:00:56
thanks guys...cleaned the ground and nearly every other connection (previous owner painted everything-everywhere). Charged the battery...started right up without any problems...you guys are great, i ended up clearing a quarter of my lot today....thanks again.
