Restoration & Repair Tips Board
530 Case CK with Torque Converter
Michael Dunn
04-26-2004 08:42:59
Torque converter is not engaging clutch causing serious slipping of clutch during operation. It appears torque converter pressure is very low even thought fluid level is normal. Gear on end of starter shattered falling into bell housing 2 weeks prior to start of problem. Could it be blocking fluid flow or movement of torque converter parts? What is the first thing that should be looked at when torque converter has low pressure?
