Restoration & Repair Tips Board
Farmall smta How hard should it be to turn hydraul
Kevin
04-27-2004 20:46:28
Just wondering how hard it should be to turn the hydraulic gear with a 1/2 inch ratchet. I took the pump apart and everything looks smooth and good. The gear turns easy until I tourque the plate bolts to 25 foot lbs and then its really hard to turn. The IT manual gives the tourque. so is it normal for the gear to be that hard to turn?
Stan(PA)
04-28-2004 18:13:05
 Re: Farmall smta How hard should it be to turn hyd in reply to Kevin, 04-27-2004 20:46:28
Didn't by any chance put in a new gasket that's thinner than the old one?
CNKS
04-28-2004 14:12:54
I have done the same thing to my Super H pump, and did not have that problem -- ask this on the Farmall board and you will get more responses.
