Restoration & Repair Tips Board
Hydraulic lift
BAQRT
04-30-2004 14:40:43
Massey Furgerson 35 Gas hydraulic lift is stuck in up position. Brief reference manual says it is a pump spring problem. Phone call to service/parts supplier says its an adjustment problem. Any suggestions?
sibby(Aus)
05-02-2004 01:18:54
 Re: Hydraulic lift in reply to BAQRT, 04-30-2004 14:40:43
BAQRT, your hyd pump control valve is stuck, remove side plate on r.h. side of trans housing held by 6 bolts, with oil level dip stick in it. Jiggle the lever that controls the valve on pump and it could unstick and release pressure4, if not the hyd pump will have to come out to replace control valve. Good Luck!!!
txblu
05-01-2004 07:19:53
Go to the Ford forum. Yesterday I posted a site I found that has full description and animated working pictures of the Ford system. It started out : Alert YOU..... ...
In the days of your tractor, I think Ford and Fergie were pretty much the same.
txblu
