Restoration & Repair Tips Board
IH 300 Utility steering wheel match
Jon
05-08-2004 05:50:23
I need to replace the steering wheel on my IH300 Utility as part of a restoration. The problem is locating an exact replacement. The original is 17- 5/8" Dia. w/3 bare spokes, to fit a 7/8" splined shaft. All the 3 spoke wheels that I can find, are made to fit a 3/4" keyed shaft. The replacement wheel specked by aftermarket suppliers is more of a modern style automotive type with 3 plastic spokes. I bought this tractor from the original owner 20+ years ago,and am quite positive that the wheel that I'm trying to replace was the original. Any help in locating a replacement would be greatly appreciated. Thanks!
CNKS
05-08-2004 18:49:24
 Re: IH 300 Utility steering wheel match in reply to Jon, 05-08-2004 05:50:23
There are anumber of vendors. Try calling Steel Wheel Ranch 785-548-7437, or OEM tractor parts 1-800-283-2122. I suppose it's possible that the 300 utility had a different shaft diameter than the 300 row crop. Mike at Steel Wheel Ranch should know.
