Restoration & Repair Tips Board
10 hp briggs key shutoff
Rick
05-11-2004 06:30:32
I swapped engines on my craftsman rider. It now does not shut off when the key is turned off. 2 wires come from under the flywheel. The red one is fused. The black one goes nowhere. There are 2 yellow wires from the key switch that go nowhere. Any help would be appreciated.
Thanks
Hermit
05-11-2004 19:02:03
 Re: 10 hp briggs key shutoff in reply to Rick, 05-11-2004 06:30:32
The red and black wires are probably from the alternator - used to charge the battery and run accessories. Look for a wire from the magneto that's not connected to anything. This should be your shutoff wire. Connect to one of the yellow wires and this should then ground the magneto when the switch is turned off. If no wire from the magneto, look for a wire from the points and try connecting that wire to the yellow wire. Have fun.
