Restoration & Repair Tips Board
MF-35 1961
Earl
05-13-2004 11:47:11
Recently overhauled my mf-35.Lost lub to rockerarm shaft. Moter carries 25# oil pressure. Why is oil not reaching rockerarms? Oil passages down to block are open.
Chris C.
05-28-2004 23:03:57
 Re: MF-35 1961 in reply to Earl, 05-13-2004 11:47:11
The rocker arm shaft has a slot on the aft end changing this slotsangle relative to the head surface controls oil flow
txblu
05-26-2004 09:48:04
I just bought one that has almost 60 psig oil pressure (Perkins 3-152D). Maybe your pressure is so low that it can't get past the mains and rods before it poops out.
You know the rocker is the last place it gets oil.
Maybe one of your journals does not have the holes on the inserts aligned with the holes in the crank so you essentially block the oil
Still thinking. Naw, your pump is worn out. If you blocked a journal it would increase oil pressure (course the journal would die from lack of lube).
You ought to have more pressure than that on a new overhaul.
txblu
