Restoration & Repair Tips Board
930 case fuel injection pump timing
joe l
05-17-2004 19:36:13
have a 930 case with the fuel injector pump removed. if any one can help with the procedure for timing the injector pump to engine it would sure make my life easier. this is a restoration project. the pump works fine and the engine has good compression. please help. thanks
CH GOOD
07-17-2005 19:12:10
 Re: 930 case fuel injection pump timing in reply to joe l, 05-17-2004 19:36:13
I HAVE THE SAME PROBLEM WITH A INTERNATIONAL ITS A 4 CYLINDER PLEASE FORWARD ANY HELPFUL HINTS OR IF YOU LOCATE A GOOD INFORMATIVE SITE PLEASE LET ME KNOW THANKYOU AND GOOD LUCK
