Restoration & Repair Tips Board
1976 Case 380 General Purpose Tractor
Dennis Minor
05-24-2004 08:18:08
I just purchased a 1976 Case 380 and I have a problem shifting back and forth between forward and reverse. Doesn't want to go into either gear very easy
Any suggestions on this problem.
Mac
05-24-2004 11:36:35
 Re: 1976 Case 380 General Purpose Tractor in reply to Dennis Minor, 05-24-2004 08:18:08
Is it shuttle shift? Could be linkage problem, if you're lucky. Next check hyd reg valve. Otherwise fwd/rev clutches may be bad I have the op manual if interested.
Dennis Minor
05-24-2004 13:07:34
 Re: Re: 1976 Case 380 General Purpose Tractor in reply to Mac, 05-24-2004 11:36:35
This tractor has a shuttle shift with clutch
Mac
05-24-2004 21:54:16
 Re: Re: Re: 1976 Case 380 General Purpose Tractor in reply to Dennis Minor, 05-24-2004 13:07:34
Dennis,
If it's just hard to shift fwd/rev lever, it's probably linkage or shuttle spool binding. I remember kicking linkage on top of tranny under steering tower accidently and it got in a bind and wouldn't shift.I wouldn't force it as the geometry is touchy and you might never get it right again. If it slips, it's a fwd/rev clutch or hyd regulator/pressure problem. You need manuals. Make sure you get right ones as there were different versions- David Brown 380s and CIH 380s. I have DB 380 hyd system and aforementioned op manual. Try Elmer on Case forum too, he's the 380 guru.
