Restoration & Repair Tips Board
Magnesium Repair
Branden
05-26-2004 15:12:07
Hello everybody. I have an older motorcycle that has a crack in the crank case cover. The cover is made of Magnesium. Over the past few years I've just put RTV sealant on it to keep oil from leaking out of it, and believe it or not it has worked very well. Thing is, I'd like to get it fixed right. I have every type of welding machine at my disposal, but I've never welded on Magnesium. I've heard it can be dangerous, and at the same time, I've heard of people that do it quite frequently. Is it possible that I can just braze this piece? I know the characteristics are like aluminum, so I doubts I would be able to do that.
Any and all suggestions are welcome.
Thanks!
Dave TX
06-01-2004 00:27:55
 Re: Magnesium Repair in reply to Branden, 05-26-2004 15:12:07
Branden,
The thing about mag is that it will burn....and water will not extinguish it either. I would use the JB Weld as well. It will work as good as any weld job if we're not talking a high stress area(torque or shear).
Gene Davis (Ga.)
05-27-2004 20:38:34
all my former experiences with trying to weld magnesium with a tig welder usually ended with a greenish blue flame as the piece went up in flames. The safest way for you to stop the leak will probably be to clean it, and remove all traces of oil and grease that have soaked into the pores of the metal, then vee the crack out and use some epoxy compound like J-B weld and smooth it down and go from there. Gene Davis
Branden
05-28-2004 21:25:00
 Re: Re: Magnesium Repair in reply to Gene Davis (Ga.), 05-27-2004 20:38:34
That's not a bad idea there Gene. I have a feeling that when it's all said and done, that is probably what I'll end up doing.
