Restoration & Repair Tips Board
PHOSPHORIC ACID
FARMIN RED
06-07-2004 10:55:28
Where does on find phosphoric acid? I have used it with the gas tank sealant kits but i don't know where to find it otherwise. does anyone know if you dilute jit with water or use it full strength. I am going to use it after a lye gravy application to strip paint off of parts. one other question. Will the phosphate coating left on the metal affect any priming of parts with a urathane primer?
Andy
06-19-2004 16:51:06
 Re: PHOSPHORIC ACID in reply to FARMIN RED, 06-07-2004 10:55:28
I believe phosphoric acid is a rust neutraliser - you put it on full strength and remove with water once the metal has changed color. We buy it at general hardware stores - as Rust Remover.Must check what strength it is next time I get a bottle.
Kevin
07-03-2004 08:48:12
 Re: Re: PHOSPHORIC ACID in reply to Andy, 06-19-2004 16:51:06
PPG Products has an excellent pre-paint procedure. 1. Apply DX 579 Metal Cleaner per direction. A. Can scrub with scuff pad as an aid.
2. Flush with water.
3. Apply DX 520 (Phosphoric Acid) while metal still wet.
4. Follow directions on product.
5. Flush with water and dry thoroughly.
6. Apply primer/sealer.
