Restoration & Repair Tips Board
wiring trouble!
Eric Allen
06-07-2004 21:50:17
Can it be explained here without too much difficulty how the wiring goes between battery, switches, cylenoid, and starter on a Farmall M? I am trying to start up our old M and it just has starter with battery cable on clylenoid, one small wire dangling from cylenoid, and wires hanging from two switches, one on/off, one 3 way. There is also an aligator clip and wire I'm guessing is for charging. Anybody got an easy to understand wire routing system for me. Thanks
Bigdog
06-08-2004 06:21:50
 Re: wiring trouble! in reply to Eric Allen, 06-07-2004 21:50:17
Original system would not have had a starter solenoid, just a heavy duty starter switch. If you truly have a solenoid in the circuit, it is modified from original. Has your tractor been converted to 12 volts?
Below is a link to the original wiring configuration:
