Restoration & Repair Tips Board
ford 8n carborator rebuild advise
Dave
06-18-2004 07:57:10
I am about to tackle rebuilding the carb on my ford 8n tractor. I have the tractor operator's manual only , I'd like to find a step by step guide to the process. I'd appreciate any suggestions
Brad-fromTN
06-22-2004 21:11:23
 Re: ford 8n carborator rebuild advise in reply to Dave, 06-18-2004 07:57:10
I've seen a step by step rebuild on the net somewhere. These are very simple carbs...carefully take it apart(Note the needle setting...I think about 1 and 1/4 turns), use some "hot" carb cleaner on it, blow everything out with compressed air and reassemble with new gaskets and it should work.
I guess I've had the most problems with rust particles, apparently from water in the fuel. Since I've been using water removing products in the fuel (Iso-Heet) I've not had any problem.
