Restoration & Repair Tips Board
JD motor cutting out after a few minutes
Andy
06-25-2004 08:59:06
The motor on my JD40 has been cutting out after running for a few minutes. It just starting doing this a few weeks ago. Runs for a few minutes then idles down quickly and shuts off. It will restart and run for just a minute than shuts off again. It has a new battery, alternator, coil and starter and fuel is getting to the carburator. Adjusted the carb needle to smooth the idle but it still cuts out. I tried running it without the gas cap (to see if the vent was plugged) but it didn't help. Could this be related to the carb/governor? If so is there a way to adjust that? Any suggestions would be appreciated.
George
06-25-2004 11:42:17
 Re: JD motor cutting out after a few minutes in reply to Andy, 06-25-2004 08:59:06
I think you have a clogged fuel line allowing only a trickle of gas into the carb. Check fuel filter and blow air back from the carb fitting back into the tank.
