Restoration & Repair Tips Board
JD G Flywheel help!!!!!!!!!!!!
Navy Chief
07-05-2004 07:42:36
I am in the middle of disassembling my beloved 1950 G Ser #44495, for restoration. I am now attempting to remove the flywheel. I got the dogleg flywheel wrench set for my Birthday last year, and it worked great for the first bolt. The problem arose when I rotated the flywheel to get at the second bolt. There appears to be recesses cast into the outer rim of the flywheel and the wrench corresponded relatively easy with the first bolt, but the second bolt has no notch on the flywheel and I am now confused as to how to loosen the second bolt to get the flywheel off. You cant get a wrench in there either! Any and all help would be greatly appreciated! R/
Eric
