Re: stuck sleeve in a farmall m
Roy
01-05-2002 16:47:18
Hi Billy
I just got through replacing 2 of the 4 sleeves on my Int 504 D. I made a sleeve puller from a piece of 3/4" aluminum. The outside diam. is the size of your cylinder and the inside will fit inside your sleeve with a hole in the center for an all thread that you can block up and with a nut on the other end you can screw this sleeve right out of the cylinder. One of my sleeves was real tight so I had to get the puller tight and tap lightly on the all thread repeating this till it poped out. Let me know how you make out. I can sent a picture of the pulley if you want. You will need to have a metal lathe to make it.
Roy
