Restoration & Repair Tips Board
Low Hydrolics pressure in Sampo Harvester
Ulrik Jensen
07-19-2004 02:38:07
Hi,
my aging "Sampo 30" harvester is only able to operate its hydrolics when operating under almost full throttle (=high RPM).
Can any of you advice me on which type of hydrolic oil this harvester uses?
I guess the oil pump might not be in prime condition any more, is it possible to eg. use a thicker oil to achieve a higher pressure af lower RPM's!?
Thanks in advance ;-)
Regards,
Ulrik
