Restoration & Repair Tips Board
Attaching Farmall Metal Nameplates
Tim IN
07-23-2004 12:52:32
I am curious as how to attach the metal nameplates on the Farmall hundred series tractors. I am having trouble finding the similar clips that attach to the stud points and lock in that were originally used. Are the original style fastners still available? Other options?
TDK
07-24-2004 19:47:21
 Re: Attaching Farmall Metal Nameplates in reply to Tim IN, 07-23-2004 12:52:32
Tim, You could try OEM.com , they may have them. I have used the 3M double-sided tape sold at any auto body supplier. It works, but make sure the nameplates are straight and the surfaces are clean.
Ol Chief
07-25-2004 19:29:19
 Re: Re: Attaching Farmall Metal Nameplates in reply to TDK, 07-24-2004 19:47:21
I am not familiar with the original fasteners,however believe most plates were originally fastened with drive screws.These look like very small round head rivets with a threaded shank.There are the multiple theads with a very very steep lead.This makes the shank look like a miniature splined shaft that has been twisted.You just drill a proper size hole and tap the screw with a small force and the plate will stay nearly forever.You will likely have to cut or grind the head off to remove the plate.I believe an easy source of supply is McMaster -Carr or maybe Granger
