Restoration & Repair Tips Board
Briggs 12 hp air filter housing...
mic
07-24-2004 23:57:54
Hello, I came into a B&S 12hp(L-Head)mounted on an old Lowe's 42" Rider. The motor had been on fire at some point and the air filter housing was severely damaged. After much cleaning and effort to clean the fire damage and remove the rat's nest(actual nest), the engine seems to be running great. Only thing I cannot fix is the AF Housing. Can someone tell me what the reason is for the AF Housing reaching into the blower shroud? Do I have to make a provision for that or can I just put an air cleaner(stack type) on the motor? Could I just plug the opening in the shroud to maintain proper cooling. Thank You!
JDK
08-05-2004 21:34:50
 Re: Briggs 12 hp air filter housing... in reply to mic, 07-24-2004 23:57:54
As common as the "12s" were for yrs,you should be able to find a housing at a local mower shop.When I need such things I check(with permission)the junk pile found behind most shops,dealer makes a couple"cash bucks" and I get what I need.Shrouds,housings,linkage parts etc.Most shops tend to buy complete bolt on replacement engines these days and other than electric starters and pulleys,most engine throwaways are still"whole".
