Restoration & Repair Tips Board
Bolens 1050 Engine Problem
Dave
07-26-2004 15:09:56
I own a Bolens 1050 tractor with the original 10 HP Wisconsin engine. In the past year or so, the engine has developed a problem where it will run fine until it warms up, then it begins to miss / cut out badly at mid to high range RPMs. It doesn't seem to matter whether it's idling or under load. I haven't been able to determine what the nature of the problem is. Has anybody seen this problem before, or can anyone offer any general advice on what it might be?
Bob Whitmoyer
07-26-2004 17:04:09
 Re: Bolens 1050 Engine Problem in reply to Dave, 07-26-2004 15:09:56
Hi Dave This can be a vexing problem but its usually electrical..First..points and condenser, Secondly , a coil thats overheating and shorting out.. Check these - unfortunatly by replacement
and see if that helps.. Look at the usually
goofy things , loose wiring on coil, switch or amp meter.
Hope this helps
Bob
