Restoration & Repair Tips Board
cub cadet125 hyd oil leak which oil or fluid
charlie
07-29-2004 21:20:19
i have a ever so slight leak, that i just began tracing on my cub 125 hydrostic tranny,,, my question is, the fluid looks a bit thin, is their a thicker fluid i can run? i don't know whats in it now, but it's fairly new oil as i bought from a knowledgable cub cadet owner and he just serviced it,,,, what's the thickest stuff i can run? so as to stop very slow leak??? thanks much
Dr.EVIL
08-03-2004 12:45:58
 Re: cub cadet125 hyd oil leak which oil or fluid in reply to charlie, 07-29-2004 21:20:19
There's a 99+% chance Your leak is the CORK GASKET between the Sundstand hydrostatic unit and the Cub Cadet rearend. It's about 2-1/2" in dia. and 3/32 inch thick and the last one I bought had pressure sensitive adhesive on one side, The "Crack & Peal" kind. $3 at My CC dealer. Problem is the half a day of labor to get the hydro unit out of the 125 and install it back into the tractor. Removing the whole rearend is the easy way on a 123,105,125,107,127,147. (Narrow Frame tractors) The center cover exposes enough of the rearend to replace the cork gasket on a WIDE FRAME without removing the rearend (109,129,149,169,1250,1450,1650 and all later hydro's like 682,782,982 (red) I WOULD NOT run something other than HY-TRAN in Your Cub Cadet. FWIW, all three of My CC's leak, even the gear drive 72, the 129, and My 982.
Red Dave
07-30-2004 07:38:59
The ONLY fluid you should use in that 125 is Case/IH Hytran. You can get it from a Case/IH dealer or a Cub Cadet dealer. Anything thicker may not be healthy for the Hydrostatic unit. It would be far cheaper to just fix the leak than it would be to damage the Hydro.
mike
07-30-2004 13:39:37
 Re: cub cadet125 hyd oil leak which oil or fluid in reply to Red Dave, 07-30-2004 07:38:59
I have run auto trans fluid in them before w/o trouble as of yet. Just an old clunk 109 someone gave,said it was junk. We had it running in an hr or 2...
