Restoration & Repair Tips Board
9n ford tractor
Jim
08-03-2004 16:30:54
how do you replace the lower lift arm case pin?
Bob
08-04-2004 14:45:36
 Re: 9n ford tractor in reply to Jim, 08-03-2004 16:30:54
You have to support the tractor, and remove the whole axle housing "trumpet" on that side .
Some people remove the LH housing, as once the LH housing is off, there is access to the pins on both sides. (The differential comes out the LH side, once the "trumpet" is removed, allowi9ng access to the RH pin.)
