Restoration & Repair Tips Board
Electrolysis--- My first Try./???
msb
08-04-2004 19:32:46
And now a million questions pop into my mind.Always seem to have a flair for going too big to start with.Got an old 170 gallon plastic chemical (EX chemical)tank.Put 90 gallons of water and 3-18 oz.cans of lye in it.Put my Massey 44 grille in it for starters.See,I said big.(Hey, it will hold a complete fender if I can make this thing work.)Hook up a 10amp trickle charger to a rusty piece of expanded steel and turn her on.Bubbles??? What bubbles?? See a very few tiny ones.What should I see besides a tank that looks like it is filled with blood 24 hours later???I can wire brush most of the paint layers off under water hose.Some shiny metal but not much.Not enough current flow??Need to see more bubbles??? Would a 120 volt transformer/rheostat be better? Have to figure out which is negative side if it will.Would it be better/quicker to use the lye gravy on large pieces first?Should I clean the electrode first??? How long should the process take???What about shelf life of lye gravy???Can I keep it around a few weeks if I don't need it all at first???Thanks for helping me have the time of my life???Radiator, you are next!!!lol,bob
Van in AR
08-08-2004 05:34:49
 Re: Electrolysis--- My first Try./??? in reply to msb, 08-04-2004 19:32:46
Check out Franks restoration page, he is the guru of lye gravy and rust removal.Link
Van>Link
Steve W (NY)
08-06-2004 09:50:56
I habe been using this method with great results. Here's what I learned. You need to make sure your electrode is constantly cleaned. I stop out to the barn and grind it clean with a wire wheel brush every few hours. You'll know it's clean because the meter on your chargere will go right up with the clean electrode. Also, I've found that patience is a virtue. Clean the parts ocasionally with a garden hose. I also strain the water with a pair of old panty hose occasionally.
Take Care Steve
Paul_NJ
08-05-2004 04:25:35
Try this link for some useful information:
http://www.cleancomputes.com/Cub/FAQ's,%20Tips,%20Technique's%20and%20Articles/Electrolysis%20Tanks/index.html
Josh (Holt T-35)
08-04-2004 22:25:25
I have been playing with the same process with good results. I cleaned up a set of Kelsey-Hayes wheels with no effort at all. You might not have enough current for that much surface area. Try just letting one corner of the part be submerged and see if you get bubbles. The bubbles shoud start showing as soon as power is applied. Even if you are overloading the charger it should put out for a short time. Be sure that the work is not touching the scrap that is connected tothe positive and that the scrap is steel and not galvanized, but fairly clean steel. I don't use a battery charger. I use a 12V 40 Amp power supply from a General Electric 2 way radio. It can handle large cueents for long periods. Hope this helps. I am a first timer with this process also. Just been playing with it for a week or so. Josh
