Restoration & Repair Tips Board
Changing the generator to alternator on my Case SC
Bill W.
08-12-2004 15:04:49
hello, i have a Case SC made between 1944-45 that I was wondering how to change the generator to a alternator the generator doesnt have the voltage regalator on it or maybe where I could get the info. thanks for whatever help you can get.bwinchester@grasshoppernet.com
jsmith
10-12-2004 10:24:09
 Re: Changing the generator to alternator on my Cas in reply to Bill W., 08-12-2004 15:04:49
I can supply you with a conversion bracket kit. It is made specifically for replacing a generator with an alternator and is adjustable for many application. This would save you a lot of time and headache. Let me know if i can further help. Anyone else looking for starter, generator or alternator parts, feel free to call Jason @ Precision Power, Inc. 1-800-794-5962.
Kendall
08-24-2004 06:49:03
Look in the archives for wiring diagrams by BobM.
He has a lot of Farmall diagrams but the alternator part of the wiring will be the same. My Super A has the one wire GM alternator. I even took it apart and painted it Farmall red. First thing I noticed was that it was not charging at idle. Bob informed me that alternators have a "turn on" speed so i reved it up and cha-ching! it started charging. After it starts charging, you can idel back and it keeps charging. Just had to reach the "turn on" speed. With some bar stock, drill press, tourch, all thread, assorted bolts, left over generator mounting parts, etc and a little imignation, you will come up with a suitable mounting bracket.
John Mc
08-13-2004 05:52:33
There are a number of very good articles on this site under "Research & Info", "Articles" on performing this conversion. I also have a '51 Case SC that I made this conversion on and am very pleased, it is a "working" farm tractor that I pull my hay baler with. If you do not find what you need, let me know and I will try to help you out.
Bill W.
08-13-2004 14:08:27
 Re: Changing the generator to alternator on my Cas in reply to John Mc, 08-13-2004 05:52:33
Could you please let me know how you made the brackets to hold the alternator thanks.
John Mc
08-16-2004 05:45:57
 Re: Changing the generator to alternator on my Cas in reply to Bill W., 08-13-2004 14:08:27
The longer support shaft for the bottom pivot point was a duplication of the original, although about 1 inch shorter, that I made on my lathe. The curved top arm for tensioning was taken from an old Plymouth car and slightly modified.
