Restoration & Repair Tips Board
John deere rear Wheel Hubs
Steve59
08-12-2004 16:12:47
Does anyone know any tricks to getting the Hubs off after the following has happened.
The 3 7/8 bolts broke near the Head. One of the Jack bolts was already broke the second has so much rust around that will not move. We have tried hitting the Collar that is supposed to go back Tried hitting the wheel itself Put a Jack against the axle with chains to the wheel. We even tried making a sleeve so that the jack pressure would go against the collar and not the axle. Also we have heated the hub to try to expand and break some rust. Tried Rocking the Wheel adjusting nut but that is froze up and won't budge. Any one who has had this problem or has some ideas that I havent tried let me know. The tractor is not running so can not drive around to try to horse it loose Thanks; Steve
harry
08-22-2004 11:54:54
 Re: John deere rear Wheel Hubs in reply to Steve59, 08-12-2004 16:12:47
I had that same experience. i tried heating the collar pried nothing. used jacks, i was able to get the bolts out of the collar put anti-seize onthe bolts the collar came right off. some how the bolts were binding part way in and wouldn't turn all the way in. it worked for me give it a try. good luck
Keith Hanson
08-14-2004 07:23:47
Take a large maul and pound against the axle, this delivers more force and may break it loose. It may take several blows but may help you out.
JMS/MN
08-12-2004 17:31:53
Dead tractors can be towed. Penetrating oil and heat. Find a pipe slightly larger than the axle, and longer- weld a cap on it. beat on it to loosen the collar. Cursing is a big part of loosening.
