Restoration & Repair Tips Board
1979 Massey Ferguson 750 Combine
bashawkid
08-14-2004 08:11:09
Hey guys,
I have a problem with this combine. The bearing has depleted on the driver side of the 5th beater at the top of the pickup. This is where the problem arises. On this combine there are 2 big pins on either side of the pickup that look like they hold the entire pickup to the combine. However these pins also hold the housing for the bearing on the number 5 beater. My question is: In order to install a new bearing on that beater, do I need to pull that big pin? What should happen when this big pin is pulled?
Thanks in advance for any advice...
jb
