Restoration & Repair Tips Board
Light truck tire pressure
Fritz
08-17-2004 04:45:52
Just got a new set of 265/75R16 Load range C (six ply) Bridgestone Dueler AT Revos for my '94 1/2 ton Silverado pickup. The tires are great and it handles like a dream - question is for running around town what is the recommended tire pressure. If I check the manual - this size tire calls for 36 - 38 psi. The manual says if running substained speeds of 60 mph+ to run 50 psi then air out to 36 - 38. The Bridgestone sidewall just say 50 psi max load. The dealer put 45 psi in them and didn't really give me a reason why it was so high or what exactly I should run in them. They basically said I should run the right air for the service I use the truck for and watch the tread wear depth when I rotate every 6 to 8000 miles.
Since I don't haul heavy loads I was thinking about 36 psi except when interstate traveling or hauling the occassional load. I really want to get max life out of these tires and the right pressure and rotation is important. Thanks for the advice.
Johndear
09-05-2004 15:09:06
 Re: Light truck tire pressure in reply to Fritz, 08-17-2004 04:45:52
There is a magic chart for tire pressure vs. load. The manufacturer of the tire should have one. The door label applies to the tires the factory put on your truck and may not apply if these tires are a different load range. If you run too much air the tire will wear in the middle. If you run too little for the load it may run hot and fail. This was the firestone problem on the Fords. As little as 10 psi of air pressure could mean half the load rating of the tire. I for one feel if folks want vehicles that ride like cars then buy cars. The only way you can have load capacity and a nice ride is with air ride and so far Detroit hasn't seen the light for air ride on anything but high dollar SUV's and luxury cars or medium duty trucks and larger. If you don't load your truck to capacity then start at 5 psi below the sidewall and watch the wear. The fronts need more air than the rear for day to day unloaded driving as 65% of the weight is up front. Less air equals more heat and less life, including your own if the sidewall fails at highway speed.
CNKS
08-17-2004 13:54:35
I have essentially the same pickup, except with 245's, also load range C -- Third set of tires, 3 brands, 40 psi in all, even wear pattern. I tow occasionally, then I up the rears to 50.
txblu
08-17-2004 05:51:18
I like a soft ride and usually carry less than sidewall pressure. The only time I do go to sidewall pressure is if I'm loading up the gvw.
For 4 ply radials on my p/u I run 27-30. Most miles are empty on the highway. On my hay truck with 10 plies, I carry 55 and take the licks as I often have a load on it. Thank goodness I don't have to drive it very far.
Now, when Ford was having the Explorer flap, one thing Firestone mentioned was underinflating their tires being a potential source of the problem.
Well the Explorer weighed around 3800 lbs and had 4 235/75R15's. Sidewall pressure was 35 lbs and carrying capacity was 2025 lbs. So x 4 tires is a tire capacity of 8100 lbs. Real stupid if you ask me. You bounce around like a pogo stick and your suspension takes a beating, and guess what? Your tires wear out in the center. Go to any tire book and look in the troubleshooting section for center wears first and guess what it says..... over inflated. Nuf said.
My daugher-in-law had one and after I found out that she was doing the above and had the center wear and all I told her to cut her pressure to 27. Worked much better and never had a tire problem.
my 2c.
Mark
Fritz
08-17-2004 18:32:30
 Re: Light truck tire pressure in reply to txblu, 08-17-2004 05:51:18
I'm going to run 36 psi for awhile and check with a depth gauge to see how they are wearing. Thanks for the advice. Sorry - I posted in the wrong category.
Kendall
08-23-2004 09:19:20
 Re: Light truck tire pressure in reply to Fritz , 08-17-2004 18:32:30
I think you hit the nail on the head. Run them for a while and check the thread depth. My Dodge 2500 with LT245/17R16 says 50psi, which makes it ride like a log truck. I tried 45 and it rode better. After a while, tread depth showed that was too much so tire dealer suggested 42. I"ve been there for a long time now and it seems to be wearing even. I bump it back up to 45 if I pull my 24ft travel trailer. Every truck/car will have an optimum tire pressure for what ever size tire it has. Sometimes you just gotta figure it out.
txblu
08-18-2004 09:46:32
10-4
Back in the '70's smooth ride was a big deal on the Detroit highway cruising tubs of the day. Mfgr recommended air pressures were on the order of 24 front, 26 rear. Course if you were going to run fast for a long time they upped it 3 psig as I recall.
This was on a bias ply tire, but (my opinion) a radial will run much cooler at low air pressure because the sidewall is designed to flex..... that's how the belt can remain straight. The bias plies weren't built for that.
Mark
