Restoration & Repair Tips Board
1953 Ford Jubilee problem
lazylane
08-20-2004 19:17:44
Starts easy, but only runs on 2 cylinders, middle cylinders not firing. Idles okay, but no power. Any thoughts or suggestions?
cole in mo.
08-21-2004 02:36:05
 Re: 1953 Ford Jubilee problem in reply to lazylane, 08-20-2004 19:17:44
Run a compression check, the head gasket may be blown between #2 and #3.
just
08-20-2004 21:08:20
for starters I would make sure that the plug wires to the 2 center cylinders aren't crossed. Fireing order 1243 clockwise. then I would make sure that the manifold is bolted down good so there is no leakes in the intake portion.
