Restoration & Repair Tips Board
Ford 640 Hydraulic problem Please Help!
Bruce
08-20-2004 22:04:50
Ok, my father has a Ford 640 and has been having hydraulic problems. The front-end loader will raise up and appears to be working ok, but the tractor won't pick up the bushhog on the back. The arms will raise just a little bit and then stop. If he unhooks the bushhog, the arms will raise all the way up with no problem. It's just when he has weight on them that they won't. He replaced the o-rings, put new hydraulic oil in, and we checked the cam follower pin. The pin was worn in half so he turned it around as a temporary fix and tryed to set the linkage to what it states in the I&T shop manual but the tractor still won't lift the bushhog up. This tractor also has a vane hydraulic pump. Any suggestions on how to fix it. Is it air in the system? Is it the vane pump? Any help would be great.
Thank you.
