Restoration & Repair Tips Board
? about 54 NAA
deadeye
09-02-2004 11:04:50
There has got to be somebody out there that can help me with minor problems and knowledge about the NAA. adjustment for brakes.6 volt system will an 8 volt battery work better or will it mess something up.what did the origanal tractor look like? Value? adjustment for the high-low lever? It kicks out in high.where would I find the serial numbers? lots more little questions. Thanks
Dave Crockett
09-24-2004 10:23:02
 Re: ? about 54 NAA in reply to deadeye, 09-02-2004 11:04:50
If the hood emblem on the front of your tractor says golden jubalee you have a 1953 (the first year of the jubalee and the overhead valve engine)but i don"t think the 53 had a high low trans in it, just a straight 4 speed. Hope this helps.
Dave Crockett
09-24-2004 10:21:48
dig
09-03-2004 10:06:56
Try the link, it'll answer most of your questions.
You have to be careful with the serial number. Mine isn't on the flat spot by the starter, it's kinda around it. It's also hand-stamped so don't sand the paint off or you'll sand part of the number off. Give ya one guess how I know that.
pete's dream
09-02-2004 11:51:41
I ain't too good at posting links so do a google search for"The vintage ford tractor resource" and get he IT FO-10 manual and the majority of your questions will be answered. No there is no adjustment on the Sherman HI-normal-low transmission. No the 8 volt will not hurt your tractor but you will have to insure that the voltage regulator is putting out enough (about 9.5) volts to keep the 8 volt charged. If there is not enough charging voltage yo will be better off with the 6 volt. If you have a tractor with ford script on the fenders and each side of the hood along with a big cyclopes enblem on the front of the hood and a very large nut in the center of the rear wheels then you have a 53/54 jubilee/naa. Serial no is located on the left side on a flat spot near the starter which is very often very hard to find and make out. Hope this helps you out.
