Restoration & Repair Tips Board
engine block paint
clearfield
09-08-2004 07:52:55
Hello group When painting a engine block on my 52 8N shouldI use any type of special paint for my engine block Will the heat from the block hurt it
Clearfield
CNKS
09-08-2004 17:16:28
 Re: engine block paint in reply to clearfield, 09-08-2004 07:52:55
Use the same paint that you use on the rest of the tractor. The block doesn't get anywhere near hot enough to burn off paint. Mainfold is a different matter. There are some high temperature paints for that purpose. I don't use them.
Kendall
09-08-2004 15:07:17
I used Plasti-Kote spray can paint on my Super A and it looks good. No evidence of heat related problems. I did paint the manifold with super hi heat manifold paint that required baking before use. It is still jet balck.
